8 Upstream Channels Are Not Bonding
I recently upgraded to the Arris SBG8300, whichis capable of32 downstream channels and 8 upstream channels. All 32 downstream channels are bonding, however, only 4 upstream channels are showing up in the gateway control panel. Would someone please be able to tell me if Cox has a limitation of 4 upstream channels or can this be changed by request? I have gone around and around with technical support and they don't have a clue. I was asking them to transfer my ticket to the Engineering department but they scheduled an appointment for a technician to come out and investigate. I have my doubts that a technician is going to be able to help. TIA!564Views0likes0CommentsDownload speed fine. Poor/intermittent upload speed.
Hi, Recently I've been experiencing issues with my upload speed. The download speed is fine. Sometimes when I run the cox recommended speed test, I'll have around 8Mbps upload, and 30 seconds later I'll get 2-3Mbps upload. I'm currently on Preferred 150/10. Definitely seeing more 2-3Mbps upload test results than anything close to 10, sometimes I've even gotten 0 back. Done the whole basic troubleshooting with multiple support representatives and boy does that get old. Yes I know how to reset. Yes I know to bypass the router. No I haven't changed any set up on my end, but somehow I'm experiencing terrible upload speeds and intermittent drops. I have an sb6183 arris modem, wrt1900ac router, upstream and downstream status look okay to me, so I'm assuming something has to be the issue from the connection to my house to the cox node, or somewhere along the way. Half the cable is new to the modem. Was told I can't have a technician come out and take a look because I'm not renting a cox modem - really?! Really baffled on this one, and could use some help. Most recent speed test and modem status linked. speed test modem status Thanks!Solved20KViews0likes50CommentsUpload Speed Issues (Once Again) in the Las Vegas Area
I've been experiencing intermittent upload speed issues since October. Before October my connection was flawless; since then my upload speed varies wildly throughout the day. Some days my upload speed is worthless; I'm a streamer and content creator and I am constantly unable to work. Cox has recommended ONCE AGAIN to send a tech to my home to inspect; but what is he going to do? My specific issue has warranted 3 tech visits, all of which "replaced lines". However the problem persists. Had a Cox tech configure the Cox modem, still had issues... Cox tech confirmed my equipment is not the culprit... Still have issues. I might have 2-3 days in a row with no upload speed issues, then the next day I'll wake up, do a speedtest and get 5mbps up. My download is NEVER effected. It's clear that this forum is flooded with upload speed complaints, it appears nationwide; but many of them are coming from the Las Vegas market. I'm at my ends wits with Cox unable to fulfill their service duties on a consistent basis. I knowCox is capable of running consistent speeds because I've received them from Cox in the past. However it seems like something is seriously "broken" on the Cox side. It doesn't take much looking around here on these forums to determine that, #1 I'm not the only customer having this EXACT issue and #2 Cox customers are continuously finding evidence that Cox IP's are in fact the culprit. My question is, what is Cox planning to do to properly restore consistent upload speeds to its users. It's a very sad day where I have to make the decision to not renew my lease on a place that I love and move out of the region entirely to find an ISP that actually maintains its infrastructure, installs fiber and doesn't constantly blame its customers for its own shortcomings. But that's the decision I keep coming back to because I am UNABLE to work as a professional with Cox Communications as my local ISP. Please advise.4.5KViews1like18Comments
