Packet Loss and Latency Spikes
This is not the first time this is happened (it happens periodically), but I am having issues with packet loss and disconnects between my modem and the ISP (hop 2). They are intermittent and very annoying. I pay $75 a month for fast internet, and I am the only person who uses it, yet I have constant problems. I had these issues with the old Cox-issed Cisco modem and my current Surfboard SB6183. Same issues with three different routers as well (Apple AirPort Extreme, Netgear Nighthawk X6, Linksys WRT1900AC). It has to be on Cox's end, but I get zero help when I call in and talk to support. They always ask me stupid questions (have you reset the modem, have you checked your router, have you tried connecting directly to the modem via ethernet, etc.) and say everything looks fine on their end. I had a tech out last month and he pulled a filter/splitter off and replaced it and said things were fixed. I was at work when he came and my housemate said that he was here for about 10 minutes. Below is a screenshot of Pingplotter, the status page of my modem, and the event log of my modem. http://i.imgur.com/1Gnp1a5.png Startup Procedure Procedure Status Comment Acquire Downstream Channel Locked Connectivity State OK Operational Boot State OK Operational Configuration File OK Security Enabled BPI+ DOCSIS Network Access Enabled Allowed Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Corrected Uncorrectables 1 Locked QAM256 73 813000000 Hz 8.7 dBmV 40.2 dB 9 65 2 Locked QAM256 74 819000000 Hz 9.1 dBmV 40.3 dB 23 48 3 Locked QAM256 75 825000000 Hz 8.9 dBmV 40.3 dB 17 56 4 Locked QAM256 76 831000000 Hz 9.1 dBmV 40.2 dB 43 133 5 Locked QAM256 77 837000000 Hz 9.4 dBmV 40.3 dB 15 84 6 Locked QAM256 78 843000000 Hz 9.8 dBmV 40.1 dB 11 67 7 Locked QAM256 79 849000000 Hz 9.7 dBmV 40.5 dB 13 60 8 Locked QAM256 80 855000000 Hz 9.6 dBmV 40.3 dB 18 69 9 Locked QAM256 89 909000000 Hz 8.8 dBmV 40.3 dB 15 55 10 Locked QAM256 90 915000000 Hz 8.7 dBmV 40.3 dB 38 61 11 Locked QAM256 91 921000000 Hz 8.7 dBmV 40.3 dB 24 98 12 Locked QAM256 92 927000000 Hz 9.2 dBmV 40.5 dB 38 31 13 Locked QAM256 93 933000000 Hz 8.8 dBmV 40.3 dB 22 81 14 Locked QAM256 94 939000000 Hz 8.2 dBmV 40.1 dB 49 107 15 Locked QAM256 95 945000000 Hz 7.7 dBmV 39.9 dB 18 57 16 Locked QAM256 96 951000000 Hz 8.2 dBmV 40.0 dB 12 69 Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 4 5120 Ksym/sec 37300000 Hz 36.9 dBmV 2 Locked ATDMA 1 2560 Ksym/sec 19400000 Hz 34.8 dBmV 3 Locked ATDMA 2 5120 Ksym/sec 24300000 Hz 35.3 dBmV 4 Locked ATDMA 3 5120 Ksym/sec 30800000 Hz 36.0 dBmV Current System Time:Mon Jan 02 20:18:17 2017 Time Priority Description Mon Jan 02 20:02:24 2017 Warning (5) Dynamic Range Window violation Mon Jan 02 19:45:13 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Mon Jan 02 19:44:45 2017 Warning (5) Dynamic Range Window violation Mon Jan 02 19:44:44 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Mon Jan 02 19:43:15 2017 Warning (5) Dynamic Range Window violation Mon Jan 02 19:40:31 2017 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Mon Jan 02 19:39:48 2017 Notice (6) TLV-11 - unrecognized OID;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.0;CM-VER=3.0; Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv4 Time Not Established Critical (3) No Maintenance Broadcasts for Ranging opportunities received - T2 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.0;CM-VER=3.0; Time Not Established Critical (3) No Ranging Response received - T3 time-out Mon Jan 02 19:38:47 2017 Critical (3) Resetting the cable modem due to docsDevResetNow Mon Jan 02 19:14:32 2017 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Mon Jan 02 14:49:12 2017 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Time Not Established Critical (3) No Ranging Response received - T3 time-out Sun Jan 01 12:18:24 2017 Critical (3) Resetting the cable modem due to docsDevResetNow Sun Jan 01 12:06:25 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Jan 01 10:18:08 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Jan 01 10:18:04 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Jan 01 07:45:18 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Jan 01 04:12:00 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Jan 01 02:49:36 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Jan 01 02:49:26 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Jan 01 01:04:25 2017 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Jan 01 00:34:59 2017 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 22:08:29 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 21:16:38 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 21:16:10 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 19:37:00 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 19:36:57 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 19:36:44 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 19:29:30 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 19:21:46 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 19:04:05 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 18:26:28 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 17:06:43 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 14:38:58 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 10:22:19 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 10:20:20 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 31 09:14:17 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 20:11:54 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 19:32:03 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 19:31:47 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 14:19:22 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 12:53:38 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 12:32:27 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 12:06:47 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 11:44:52 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 11:16:42 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 09:43:45 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Fri Dec 30 08:47:55 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 23:01:39 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 17:40:27 2016 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 17:40:27 2016 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 17:40:27 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 17:37:28 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 15:10:05 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 15:09:58 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 13:05:10 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 13:04:38 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 12:16:33 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 10:44:07 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 04:02:33 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 02:35:07 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 02:34:58 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 02:34:46 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 01:28:56 2016 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 01:28:56 2016 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Thu Dec 29 01:28:56 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 20:58:38 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 14:04:29 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 12:26:04 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 12:25:50 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 10:26:12 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 10:24:58 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 10:23:40 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 10:23:38 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 10:23:36 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Wed Dec 28 10:18:33 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Tue Dec 27 18:29:10 2016 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Tue Dec 27 18:27:38 2016 Critical (3) Resetting the cable modem due to docsDevResetNow Tue Dec 27 14:13:19 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Tue Dec 27 14:06:05 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Tue Dec 27 13:57:24 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Tue Dec 27 12:15:27 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Tue Dec 27 11:34:07 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Tue Dec 27 09:26:31 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Mon Dec 26 17:42:40 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Mon Dec 26 04:52:59 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Mon Dec 26 04:52:45 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Dec 25 14:20:37 2016 Critical (3) Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Dec 25 13:40:15 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Dec 25 09:58:00 2016 Critical (3) 16 consecutive T3 timeouts while trying to range on upstream channel 0;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Dec 25 09:58:00 2016 Critical (3) Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Dec 25 09:58:00 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Dec 25 09:39:19 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Dec 25 04:37:19 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sun Dec 25 00:05:00 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 24 14:36:22 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0; Sat Dec 24 09:44:20 2016 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=74:ea:e8:f0:7b:4d;CMTS-MAC=00:21:a0:fb:6a:74;CM-QOS=1.1;CM-VER=3.0;8.6KViews0likes24Comments!!!!---Constant Internet Speed Issues---!!!!
Since I have had Cox I have had constant connectivity issues. Our modem has been upgraded to the Netgear N450 CG3000Dv2 to assist with our previous connectivity issues. We were running at 15 Megs on our previous plan and had constant speed of 8 Megs MAX. I just upgraded our internet to 50 Megs and we are lucky to get 2 Megs of download speed on a good day. We are paying almost 2x the prior cost for a slower speed. I checked our modem compatibility and it states the hardware can process up to 150 Megs of download speed. I have hard RESET the modem and RESET the connection on the online tool multiple times now. I understand Cox to be more reliable than other internet providers. Their customer service is extremely friendly, but unfortunately I have not been able to have any of these issues resolved. I have our most recent speed test provided below. Of which, I see it doesn't show up. Basically, it details we are running at 1.66 Megs on download and 2 Megs on upload. Our upload speed is faster than the download! Any advise or information would be greatly appreciated.2.2KViews0likes1Comment
