Sort By
- CurtBValued Contributor III
Is there physical damage to the remote or does it just not work? Have you tried replacing the batteries?
- CrystalSFormer ModeratorOh no! Let's get started. Depending on the box, you may be able to change the channel by pressing the channel up or channel down button on the front. If you don't have any buttons on the front of your box. The only other option is to swap out the remote at the nearest Cox Solution Store. -Crystal Cox Support Forum Moderator
- 10 years agotintinmilou
- 5 years agoJudyG
- 10 months agoWiderMouthOpen
- 29 days agoHxJ
