Steve_A
5 years agoNew Contributor III
Cox Connect App will not reset my DVR and mini boxes
In Cox Connect I can click on the TV icon which then display Reset My Cable Connection which then has a big blue button call Reset My Connection. I should be able to press that button and have cox send a signal to reset all my cable and DVR boxes BUT when I click that blue button it does nothing. Pressing big the button does not act like a push button It doesn’t react
Why is that button not doing anything?
- Hi Steve, please ensure your device's operating system is up-to-date with the latest firmware version. I would also suggest uninstalling the app, and restarting the device. After the device has restarted, please reinstall the Cox Connect App. -Kevin M. Cox Support Forum Moderator
