Tennisguy's avatar
Tennisguy
Miami Open Tennis - Can't set series record - Solution
This is an ongoing problem with the new Contour 2 box and nothing is done to fix it.
I have a solution that allows a live series to be recorded by an easy one click.
Currently you have to go to each event, because each is listed separately on the guide, and then select record, which takes about 5 minutes.
Solution: Allow key word search, like "Miami Open", then allow record all. easy!
  • Hi Tennisguy,
    I have shared your feedback with our Product Development Team. Thank you for reaching out to us through Cox Forums.
    Maria L.
