Sort By
- BrianMModeratorAre you referring to a small square in the corner of the screen? The new Contour system does not have that option. You can however adjust the background darkness so that you can see the channel behind the guide a bit. This can be adjusted by hitting the contour button, go to the settings icon (click ok) then go to Preferences> General > Background Darkness Level and set to 1 for the lowest setting.
Brian
- 5 years agokristiemom26
- 9 months agoBrain01
- 5 years agosnik
