Sort By
- BeckyModeratorHi Gymanime, from what I understand, you will only be able to set up a Contour 1 series recording on an SD channel if the channel is not offered in HD. Since the HD video format was dual-mapped to the SD channel locations, a series recording with the channel option set to "400 TV Japan SD only" will still record in HD. -Becky, Cox Support Forums Moderator
