Bobbbbbb
6 years agoNew Contributor
Selecting under 1000 channel jumps to corresponding 1xxx channel and displays error
Not long ago, the channels under 1000 were switched to HD which is fine.
The problem is when I tune to channels under 1000 (e.g. ch 9), sometimes it jumps to the 1xxx channel (e.g. ch 1009) and then it displays a message I'm not subscribed to the channel. I then hit the "last channel" button and it goes back to the under 1000 channel (e.g. ch 9) and displays fine.
Two problems: (1) it should NOT jump to the 1xxx channel and display an error. (2) I lose the ability to go back to the actual previous channel using the "prev channel" remote function. It will only go between 9 and 1009 even if I was watching channel 5.
This bug has been around since they changed the under 1000 channels to HD.
