Sort By
- yakContributor III
Do you have these shows set up as "Series Recordings" or do you choose them one-at-a-time? Is the DVR recording shows you like but did not set for recording? or are they just selected randomly?
- LacMartNew Contributor
Actually I am not choosing them, as I did not set them for recording. They seem to be random.
- MarkM1Former ModeratorLacMart,
Do you have multiple DVR boxes in your home? If so, have you attempted to do a hard reset of all of your cable boxes to see if that works?
Mark M.
- LisaHModeratorHi LacMart. You want to check the series recordings to make sure you are recording just new shows and not all. The setting may depend on which DVR you currently have. Check out www.cox.com/.../recording-programs-on-the-advanced-tv-dvr.html. For Contour 2, check out www.cox.com/.../schedule-access-and-manage-contour-2-recordings.html. Thanks, Lisa - Cox Support Forums Moderator
- 3 years agoFlighthawk
- 7 months agonek_endhuku_ra
- 8 years agopkancel
- 8 years agoxXBrianXx
