Hannie
6 years agoNew Contributor
Is my Tuning Adapter bad or my TiVo (with stats)?
Hi there, I have had Cox out numerous times to try and fix some signal issues as they said I had a weak signal from the street to the house, but from street to colo it was fine. The finally hooked up a booster but my cable signal never improved but my internet signal did. The booster affected the cable to where it is now pixelating terribly.
Cable was fine before the booster but signal has never been above 70%, and it is now down to 67%.
I have attached some info to try see if someone can verify that the Tuner Stats are within range and acceptable as I know the TiVo's is not. I am close to buying a new TiVo but want to be sure.
Tuner:147.000 MHZ
FDC: 75.5MHZ
RDC:16.25MHZ
Tuner:-2dbmv
FDC: -9dbmv
RDC: 50 dbMv
FDC: 0/Sec
RDC: 561 uSec
