Stewart_H's avatar
Stewart_H
7 years ago
Playback error on all recorded shows
After re-booting the Explorer 8240 HDC I'm getting a 'Playback error'.  Can someone assist???  Thanks....
  • Stewart H, since rebooting the box does the same occur with new recordings?
    • Stewart_H's avatar
      Stewart_H
      Hi....thanks for your reply...Yes, I can record & playback new TV shows, but no previous recorded shows will playback......
    • BrianM's avatar
      BrianM
      Is this just a couple recordings that were recorded around the same time frame or is it a bunch that you know have worked previously without any issue? It sounds like there could be something going on with the box itself.
        Stewart_H
        BrianM:    There are about 15-20 recorded TV shows from many different dates & times and yes I have played them previously and saved them as well.........
