Finding my "favorites"
TV Forum
Activity: 2 Replies | 0 Subscribers
This question has been solved
Posted by
I've gone through the new movie listings On Demand and marked many as "Favorite" so I can find them easily.  Not sure how that works though..... does anyone know how I can find/sort the movies I've marked as "Favorite" On Demand?  I've tried just about everything.
Thanks for the help!
Verified Solution
  • Posted by ColleenD
    23 Feb 2018 8:48 PM
    Accepted Answer
    SunnyOC, You should be able to locate your favorites by pressing the Contour button then navigating to Saved and then Favorites. I hope this helps.
All Replies
  • Posted by SunnyOC
    24 Feb 2018 1:20 PM
    Thank you for the note!  I just located all of my favorites :-)
    Thanks again!
