Cox Remote Code Finder
TV Forum
Activity: 2 Replies | 0 Subscribers
This question has been solved
Posted by
I need to replace my Cox remote control.  The buttons within the center of the remote are becoming unresponsive and it takes a lot of pressure to activate them.  A lot of pressure.
To plan for the replacement, I'm trying to research the codes for my television on the URCSupport webpage.  However, that too is unresponsive.
On the webpage; I can enter my provider (Cox Communications), select my remote (Cox URC8820) and click CODE FINDER.  The page then automatically scrolls to the REMOTE CONTROL SETUP section.  However, it's just a gray box with a red border.  I can't click within it, there's no interaction with it and I don't know what info it wants.  I assume it wants the make/model of my TV but there's no place to enter it.
Granted...I've using a less-advanced, 32-bit browser but my less-advanced browser is up-to-date:  Firefox ESR (52.6.0).  I've accepted cookies and disabled add-ons...but nothing happens.
Can a moderator research ALL possible codes for the following?
 - Cable Box:  Cisco Explorer 4642HDC (CSH4642)
 - Remote Control:  Cox URC8820
 - TV:  Panasonic TC-P50ST50
Verified Solution
  • Posted by JonathanJ
    1 Feb 2018 5:59 PM
    Accepted Answer
    @Bruce
    The code for Panasonic 10051, 10250 you can also try these 2 links http://bit.ly/2sOzvDI or http://bit.ly/2E4QaZT. Let us know if that helps.
All Replies
  • Posted by Bruce
    2 Feb 2018 8:54 AM
    Thanks.  I didn't know Cox had User Guides (PDF) available at
    cox.com/residential/support/remote-control-user-guides.html
    Solved and Closed!
