contour 2 box
contour 2 box
TV Forum
Activity: 2 Replies | 1 Subscribers
This question has been solved
Posted by
Contour 2 box never powers off.  Is this normal ?
Verified Solution
  • Posted by Davidoo
    5 Oct 2017 6:07 PM
    Accepted Answer
    Yes, I think it is.  I just got a Contour 2 myself a couple of weeks ago.  The default is the power savings is turned off.  I went into the settings and had mine go off after 2 hours of inactivity, so now when I get up in the morning it is off.  I had it set for 1 hour, but even if you are watching something and don't change the channel, it will give you a warning that it is going to turn off, so I set it at 2 hours.
  • Posted by JonathanJ
    5 Oct 2017 7:23 PM
    Accepted Answer
    A Contour 2 receiver that is powered down is actually in Power Save mode. For more information please check the link
