MoCA Issues: 40 Channels Lost - Tivo Bolt & TiVo Bridge
TV Forum
Activity: 22 Replies | 1 Subscribers
Posted by
MoCA works, but when it's turned on almost 40 channels are lost. I've read/followed instructions and tried restarting/disconnecting everything multiple times (including WiFi & Modem), even changing the cable splitter. Nothing changes. WiFi streaming works fine. But as soon as I turn on MoCA the channels are lost. Seems random. Other COX boxes/TV fine. I think it's the CC and/or TA. Always had issues in the past (missing channels) w/ CC, but not this time. Only w/ MoCA now. The only thing not installed is a POE filter, but why would that make a difference? MoCA works.
Equipment:
TiVo Bolt (COX Motorola CableCard)
Tuning Adapter
TiVo Bridge
Channels Lost Following Initial Set Up w/ CableCard Pairing/Tuning Adapter:
1022*
1061*
* Regained channels after a couple restarts.
Channels Lost Following MoCA Set Up: Message: "Searching for a signal on this channel. (V52)
1002
1005
1006
1008
1009
1010
1013
1014
1019
1021
1027
1028
1043
1045
1046
1048
1051
1052
1053
1057
1058
1059
1060
1062
1068
1069
1072
1075
1080
1088
1106
1108
1110
1113
1300
1301
1342
1352
1354
1366
All Replies
  • Posted by ChrisL
    11 Aug 2017 6:24 AM
    @ihatecox2
    If you haven't installed the PoE filter yet that could be a problem. The filter doesn't make MoCA work but rather it prevents MoCA from interfering with other services and ultimately leaking into our network and affecting other customers. -
    -Chris
  • Posted by ihatecox2
    11 Aug 2017 11:33 AM
    I was going to try it [POE filter] but it doesn't make any sense as to why it would help this situation. I hope it does. But if it doesn't help... then what? I'm also going to pick up a couple more CableCards, as well as another Tuning Adapter, just to make sure it's not related to those.
    From TiVo:
    MoCA POE Filter. A MoCA (Multimedia over Coax) "Point of Entryfilter is designed to prevent MoCA signals from leaving your home through the cable box or radiating out of an antenna, and may improve the performance of a MoCA home network. Install it at the point of entry of your antenna or cable line into your home.
    Nothing about preventing loss of channel signals.
  • Posted by ChrisL
    11 Aug 2017 11:40 AM
    @ihatecox2
    I did also see Tivo guides that say when this happens you may need another filter for the tuning adapter. Keep in mind that MoCA interferes with cable service if not correctly installed. With that in mind it makes sense you would lose services when enabling MoCA.
    -Chris
    11 Aug 2017 11:46 AM
    ok... I'll try PoE filter as mentioned; at entry to house and at TA.
    The TA was suppose to come with a POE according to instructions on COX but it's a different TA set up.
    11 Aug 2017 2:14 PM
    I just discovered that MoCA w/ TiVo Bolt requires a specific type of PoE w/ 70-80dB rejection - meaning their own TiVo PoE filter. How convenient!
    • TiVo authorized MoCA (PoE) filter for TiVo Bolt, TiVo Roamio and prior TiVo models. PoE filters that are not TiVo approved or authorized will likely not work to protect your home network. The TiVo Bolt, in particular, requires a specialized filter that provides 70dB - 80dB of rejection.
    • Authorized and approved by TiVo for use with TiVo DVRs. Specially designed for use with TiVo DVRs.
    • Bandstop provides 70-80dB of rejection.
    12 Aug 2017 2:57 AM
    Does it matter that the coax cable is from wall>tuning adapter>tivo instead of from wall>splitter>TA/tivo as shown with TiVo’ Tuning Adapter Installation?
    https://support.tivo.com/articles/Features_Use/How-to-Install-a-Tuning-Adapter-for-Switched-Digital-Video
    i also realized that the USB cable needs to be connected to top input. Not sure what it affected if anything.
  • Posted by ChrisL
    12 Aug 2017 4:31 AM
    @ihatecox2
    The info I saw suggested that the PoE filter be installed as close to the point of entry as possible and one at the the SDV adapter if necessary.
    -Chris
    12 Aug 2017 11:11 AM
    Yes, I got that. But what about the Tuning Adapter installation instructions. My Tuning Adapter has In and Out. Does it matter if it’s daisy chained or split to TA and TiVo? What is SDV?
    i haven’t had a chance to inspect the cable TV entry box yet. There’s most likely an old splitter or two and maybe a signal booster.
  • Posted by ChrisL
    12 Aug 2017 11:15 AM
    @ihatecox2
    This is the part where I would have to defer to Tivo support for a knowledgable answer. If the box needs to use MoCA to communicate with other devices that will fail should the filter end up in the path between them. If this is a problem you may need to modify the wiring to suit your needs.
    -Chris
    14 Aug 2017 1:12 PM
    The cable drop box is a mess and I can't figure out which one is the incoming line. Here's what I found:
    1 x 4-way spliiter
    1 x 2-way splitter
    1 x booster
    I'm trying to insert more pictures but it won't upload after selecting with browser. Only one time.
    14 Aug 2017 2:15 PM
     Finally worked...
  • Posted by JonathanJ
    14 Aug 2017 5:50 PM
    @ihatecox2
    Great please let us know if you have further issues.
    17 Aug 2017 2:24 PM
    Not sure which one is the incoming cable. Also, do you think the booster is/can cause issue with MoCA? And should I replace the splitters? They look rather old and are rated to 1000Mhz. TiVo Bridge/MoCA requires 1650MHz, even though it works, except for almost 40 channel signals being lost.
    I wonder how much it would cost to have COX Tech visit and replace splitters and cables at box from drop cable?
  • Posted by ChrisL
    17 Aug 2017 2:37 PM
    @ihatecox2
    All of our equipment is rated for 5-1000Mhz. If you require something different that would have to be acquired via other channels.
    -Chris
    28 Aug 2017 3:07 PM
     Gave up. Nothing worked. I read/followed instructions and tried every conceivable set up w/ PoE filters, restarting everything multiple times w/ cable and network, also replacing splitters and cables, and MoCA would not work. With both PoE filters in place (at drop box/entry to house and at/before Tuning Adapter) MoCA had no connection/internet, and also no IP most times, and even if it did, it still did not work. I tried removing PoE filter at Tuning Adapter but no change. Funny how I lose almost 40 channel signals w/o PoE filters but MoCA works, yet w/ PoE filters in place as everyone/thing says to have, there's no loss of signals but MoCA doesn't work. Wi-Fi works. A complete waste of time and money. Hard to imagine no one else with similar problem too, yet no other replies.
