Simultaneous ring very inconsistent?
A couple of days ago  I noted that simultaneous ring  was now available in settings. So, I entered the number for my cell phone and nomorobo.  Since then, I noticed that most of the junk calls are getting through. I looked the numbers up in a browser and found nomorobo recognized several numbers as spamsters.  I also noted that my cellphone did not get the calls either. Since nomorobo has worked on several and my cell was not getting all the calls, it appears that it is simultaneous ring is working sporadically. Is anyone else having this problem?
