bluetooth headset for 3 lines
We are a cox telephone customer and wondering what bluetooth headset would handle 3 phone lines.
  • I think you mean 1 Bluetooth headset with 3 simultaneous connections.  Multipoint allows 2 simultaneous connections.  There is now an Advanced Multipoint but I don't believe if it allows more than 2 connections.
    I don't think you're talking about pairing because multiple devices can already be paired to one headset...just not simultaneously used.  Multiple devices in this case would mean:  to be remembered, woken up and quickly swapped out to use.
    I'd search Bluetooth Headset 3 Simultaneous (or Concurrent) Devices.
  • Sure you mean bluetooth and not cordless? Are you asking what cordless phone can handle 3 lines? If so, by lines, do you mean headsets, or 3 separate lines with their own phone number?
