Sort By
- COX_TECHNew Contributor
Do you live in one of the following areas?
- Baton Rouge, LA
- Gainesville / Ocala, FL
- Gulf Coast / Pensacola, FL
- Macon, GA
- Roanoke, VA
If... Then... Yes Call us to set the number of rings. The network technology requires us to make the change for you. No Continue to the next step. 2Press *78.
Result: You will hear a stutter, then a regular dial tone.3- Enter the number of rings between 2 and 9.
Note:The default is four rings. - After entering the number of rings, you will hear two fast busy signals letting you know your changes are complete.
- After listening for the confirmation tone, hang up.
Note: There are some isolated cases where the four-ring default cannot be changed using these steps. In this case, contact your local Cox Center for assistance.
- Baton Rouge, LA
- Macon, GA
- Roanoke, VA
- 9 years agoNighthawk
- 10 months agoWiderMouthOpen
