update to tv caller id
Phone Forum
Activity: 4 Replies | 1 Subscribers
This question has been solved
Posted by
tv caller id worked for just a while.  Called support and have a tech coming on Wednesday to fix the problem.
Verified Solution
  • Posted by connflash
    5 Oct 2017 1:22 PM
    Accepted Answer
    tech was here and the problem is solved.  when service was installed a week ago the installer used a refurbished cable box.  The tech today changed the cable box to a new one.  Lo and beholed the tv caller id is now working. I don't understand why a new installation would use a refurbished cable box. That's it for now..
All Replies
  • Posted by JonathanJ
    3 Oct 2017 3:00 AM
    Please let us know if you have issues once the technician leaves.
    3 Oct 2017 8:20 AM
    I surely will do that
  • Posted by Bruce
    5 Oct 2017 1:56 PM
    Yes, please keep us updated on your fix.
    The problem isn't Caller ID on TV can't be fixed.  The problem is it's only been a temporary fix.
    Cox sends refresh signals...re-provisions services...and now, swaps boxes, to "fix" the problem, but the problem always returns.
    Check out this thread:  http://forums.cox.com/forum_home/tv_forum/f/4/t/18950.aspx
