Extremely high jitter (over 140ms). VOIP/stream issues
I work from home for a tech company (Elauwit). Funny enough we are contracted by COX to help out in Florida, Louisiana, and California. Because I work from home, I need a stable connection. I use a headset plugged into the computer and use a program called talkdesk to call customers. This is where the issue is. Starting a few days ago customers would tell me I was breaking up and they could not hear me. So I began to do some testing to find out why. I replaced the Ethernet cord plugged into my modem, bypassed my router, and even went as far as to replace the modem (since the COX rep claimed that was my issue). The issue is still present. My Jitter will fluctuate from around 3 to 150 or higher. My work requires the jitter to be as close to 0 as possible and it always was before (at worst it was 3ms). The ping is always fine. I never drop packets and everything else is seemingly fine. The only time I have an issue is when I try and stream something (Twitch, youtube, etc) and when I am making calls for work though the computer. Please help, because my livelihood depends on a solid connection.
Model Name: SB6141
Vendor Name: ARRIS Group, Inc.
Firmware Name: SB_KOMODO-1.0.7.0-SCM00-NOSH
Boot Version: PSPU-Boot(25CLK) 1.0.12.18m3
Hardware Version: 7.0
Serial Number: 397179509642274301012022
Firmware Build Time: Jul 22 2016 08:13:57
Jun 21 2018 07:53:16 | 3-Critical | R02.0 | No Ranging Response received - T3 time-out;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jun 21 2018 05:04:36 | 6-Notice | I401.0 | TLV-11 - unrecognized OID;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jun 21 2018 05:04:36 | 5-Warning | Z00.0 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jan 01 1970 00:00:34 | 3-Critical | R02.0 | No Ranging Response received - T3 time-out;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jun 21 2018 05:03:22 | 6-Notice | N/A | Cable Modem Reboot from Software upgrade ;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jun 21 2018 05:03:20 | 6-Notice | E111.0 | SW download Successful - Via NMS |
Jun 21 2018 05:02:06 | 6-Notice | E101.0 | SW Download INIT - Via NMS |
Jun 20 2018 12:57:40 | 6-Notice | I401.0 | TLV-11 - unrecognized OID;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jun 20 2018 12:57:40 | 5-Warning | Z00.0 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jan 01 1970 00:00:47 | 3-Critical | R02.0 | No Ranging Response received - T3 time-out;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jan 01 1970 00:00:15 | 6-Notice | N/A | Cable Modem Reboot due to power reset ;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jun 20 2018 12:34:11 | 3-Critical | R02.0 | No Ranging Response received - T3 time-out;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jun 20 2018 12:34:04 | 6-Notice | I401.0 | TLV-11 - unrecognized OID;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Jun 20 2018 12:34:04 | 5-Warning | Z00.0 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=3c:df:a9:44:26:d5;CMTS-MAC=b4:de:31:2b:e9:d0;CM-QOS=1.1;CM-VER=3.0; |
Configuration | |
Frequency Plan: | North American Standard/HRC/IRC |
Custom Frequency Ordering: | Default |
Upstream Channel ID: | 4 |
Favorite Frequency (Hz) | 789000000 |
DOCSIS MIMO | Honor MDD IP Mode |
Modem's IP Mode | IPv4 Only |
DHCP Server Enabled |
Downstream | Bonding Channel Value | ||||||||
Channel ID | 2 | 1 | 3 | 4 | 5 | 6 | 7 | 8 | |
Frequency | 789000000 Hz | 783000000 Hz | 795000000 Hz | 801000000 Hz | 807000000 Hz | 813000000 Hz | 819000000 Hz | 825000000 Hz | |
Signal to Noise Ratio | 38 dB | 37 dB | 38 dB | 38 dB | 38 dB | 39 dB | 39 dB | 38 dB | |
Downstream Modulation | QAM256 | QAM256 | QAM256 | QAM256 | QAM256 | QAM256 | QAM256 | QAM256 | |
Power Level
7 dBmV | 6 dBmV | 7 dBmV | 8 dBmV | 9 dBmV | 9 dBmV | 9 dBmV | 8 dBmV |
Upstream | Bonding Channel Value | |||
Channel ID | 4 | 3 | 2 | 1 |
Frequency | 40400000 Hz | 35600000 Hz | 29200000 Hz | 24400000 Hz |
Ranging Service ID | 1938 | 1938 | 1938 | 1938 |
Symbol Rate | 2.560 Msym/sec | 5.120 Msym/sec | 5.120 Msym/sec | 2.560 Msym/sec |
Power Level | 39 dBmV | 39 dBmV | 39 dBmV | 39 dBmV |
Upstream Modulation | [3] 16QAM [3] 64QAM |
Ranging Status | Success | Success | Success | Success |
Signal Stats (Codewords) | Bonding Channel Value | |||||||
Total Unerrored Codewords | 682592287 | 682609568 | 682601395 | 682582038 | 682575433 | 682577116 | 682575809 | 682575840 |
Total Correctable Codewords | 12 | 2 | 81 | 1663 | 14 | 18 | 46 | 2546 |
Total Uncorrectable Codewords | 618 | 597 | 509 | 564 | 611 | 637 | 1477 | 657 |
Please let me know what other information may be needed. Thank you for your time.
