Universal Remote - Is there a 3rd party remote that works with Contour??
Our contour remote is not compatable with the our Denon amplifier so we are forced to use 2 remotes now.   To turn the TV on and change the volue on 1 remote and the Contour remote to change cable channels, etc...
Doesn't seem like much an upgrade when we have been using one remote for all systems for years now.
  • Hi Jodonnell,
    There are 3rd party remotes capable of being used with the contour however we do not have a list of compatible remotes to provide.
    David
    Tech Support Forums Moderator
  • I have had good luck with the Universal RCA remotes sold at Walmart. Here are the codes;
    Comcast .................................. 51376, 51877, 50476, 51982, 52187
    Cox .............................................................................. 51376, 51877
    By the way, do you have Contour or Contour 2 boxes? The trick with Contour 2 remotes is to try Comcast codes since Contour 2 is leased by Cox from Comcast.
