Becky
Hi Tony, just like on the Rovi platform, Contour 2 makes recording decisions based on the priority of the recording. Learn how to review and manage scheduled recordings at www.cox.com/.../managing-contour-2-scheduled-recordings.html. I find that accessing the “Series Priority” menu is slightly tricky until you get the hang of it. Press the Contour button on the remote control and navigate to the “Saved” menu. Use the right arrow button to highlight “Scheduled.” Pressing the down arrow automatically puts you into the list of scheduled recordings. Press the up arrow to highlight “View recordings.” Press the right arrow to highlight "Series Priority" and then press OK. Use the up and down arrows to move the scheduled recordings within the priority list, and then press OK. When you’ve ordered the list per your desired priority, use the right arrow to highlight “Confirm” and then press OK. Please let us know if you have any other questions. -Becky, Cox Support Forums Moderator
TonyofAZ
6 years agoNew Contributor
Thanks Becky that will set me on the right path.
- 8 months agonek_endhuku_ra
- 9 years agoBruceL
- 23 days agoMojoGene
