It's on their end but until one of their techs tries watching TNT on their phone you will get nothing but run-around.
On both my mobile apps and desktop browsers i will get no sound on specific channels. And it started a month or less ago. And i have not updated my mobile Contour app in that time.
However, i did get the audio back half the time when visiting the SAP settings and choosing either espanol or video description, whichever happens to be available.
- CrystalS5 years agoFormer ModeratorHi Ucjuicy, our video engineers ae investigating this issue. What channels are impacted? -Crystal
- letti0015 years agoNew Contributor III
I am back to the sound not working 😞 This is really odd for sure. A majority of the channels work fine. It is just a few that do not work with sound. the video description button is not able to be changed any more.
- StephanieS5 years agoModeratorletti001
You're in an outage area at this time, that could be why you're having the audio issues. Once this outage has cleared please reach back out here so I can take a look and see what's happening with your audio. Service should be up and running at approximately 6am.
StephanieS
- ekhawaii5 years agoContributor
letti001....Cox says outage in area, are you not getting any sound/video on all channels or just on specific ones. Does the SAP slider not work either. I noticed that, depending on what station you view, different 3 indicators light up. No light, no option available. As CurtB says above, different markets have channel grids that differ. Cox also mentioned to check if CC works on the station, although it has nothing to do with sound working.
Secondary audio works. CC works. Nearly all channels work. And this problem has been going on for several weeks. Not new. I do not think it is from outage. On the other hand, I do not know what to think as it is quite odd.
When the video description tab is available, I can get the normal sound albeit with the video description.
- CurtB5 years agoValued Contributor III
I tested https://watchtv.cox.com on my desktop using Chrome. The video and sound worked for every channel I tested... CNN, TNT, Paramount, WGN. I don't have the Contour app installed. Is there anything about the app that could possibly affect an individual's account settings on a Cox server in a way that would alter performance when accessing the website with a desktop browser?
Also, just to eliminate possibilities, did you verify that neither the website's sound or your computer were muted when viewing channels with no sound?
CurtB, so it works for you, interesting. I tried Chrome again this morning (usually use Firefox) but have also found the issue on Edge. I'm on W10 machine here in SoCal.
For Chrome, TNT (18), Freedom(19), Paramount(52), WGN(68) plus newly found trvl(53), tlc(54) bravo(55) all did not work. CBS(2) & weather(51) worked. When channels failed, it was usually the sound. On a few, the screen was blank, or the video was stuck. After sliding the SAP to the right, the Sound did appear. Sometimes I need to wait till the "Attempting to Resume" refresh screen to appear. On a few, if SAP is not there, try the Video Description icon.
On the platforms, I had to Enable Adobe Flash. Also, I do not have the App on my cell phone. I do check my COX account for recent phone call history, account info, and this forum.
My email to COX said ticket CUI000008292144 was created. Based on this forum comments, both the watchtv and cell phone App may be affected. Not sure why your Chrome worked.....do you have Firefox or Edge.
It's normal for Adobe Flash to have to be enabled for Chrome. I don't use Firefox or Edge. While we may be accessing the same network channels with the same web browser, we're in different markets. That's a Cox variable that may produce unpredicatble results.
I only have two minor issues with the https://watchtv.cox.com website.
1) The "Controls Auto-Hide Delay" event doesn't fire when a new channel is selected. It requires a cursor move or full screen change for screen controls to be removed. It's a minor issue and the main reason it's annoying is because it would be such a relatively simple thing to fix.
2) When "X" is entered to exit a channel, the current channel isn't always the channel in the grid that's selected. It complicates grid navigation using the keyboard.
I contacted Cox about both of these minor issues a long time ago. As far as I know, there hasn't been an update to that site recently. I don't expect a change before the update to replace Adobe Flash that is scheduled to be retired next year.
- 5 years agokristiemom26
- 7 months agojillrenee1973
- 2 years agoWiderMouthOpen
- 10 years agoglo
