Bruce,
Thanks for the information yesterday, I learned some things about HDMI and also found menus on my TV I didn't know existed.
I did turn off the Samsung Anynet+ function (it was on). I always have had the Samsung internal speakers turned off. Got up this morning and the system still reverts to 720p and 2 channel (stereo) audio.
1080i is one of the options I can select from the contour box. Will try that.
I think I'm also going to try disconnecting the optical and HDMI inputs going to the contour box and see what happens over night.
You would think contour would just remember my preferences and the TV/audio would pump out whatever format the programing is broadcasted in, that's how things worked prior to switching from Verizon.
I mentioned earlier that I found instances of other people having a similar issue as mine (with the new contour 2 box) and replacing the box was the fix, but I certainly don't mind going through some troubleshooting steps.
As always, greatly appreciate the assistance.
