Ok, my somewhat older TV and Audio info :
TV - Samsung model # UN46D6003SFZA (connected to Contour via HDMI)
Audio - Sony surround amplifier model # STR-DE595 (connected to Contour via optical cable)
My test this morning was on channel 1301 (HBOHD)
I checked numerous channels at lunch and the Contour preferences remained set at 1080p and Dolby 5.1 for each. I can provide a list of specific channels if this info is needed but that list would get long quickly. I do tend to view only HD channels.
I did initiate a re-boot of the Contour box (actually, the re-boot was due to a lack of signal detected since a Cox employee was installing a new line between the house and the nearest junction point in my neighbors yard while I was home at lunch) and the Contour preferences reverted back to 760p and stereo. Not sure if that is normal for theses preferences to re-set during a re-boot or not, just thought I would add the info.
Turning Contour/TV/Audio off and back on numerous times during the day or letting Contour go to sleep mode does not alter video and audio preferences of the Contour box. The only time it appears to revert is during overnight hours or if I manually re-boot the Contour box.
Does Contour normally perform routine maintenance actions or re-boot itself in the middle of the night?
