If you have series recordings set for the standard definition channel, you will need to remove them and start a new series recording since the standard definition channel does not exist anymore. This change was made to make it easier to navigate to HD channels by pressing less numbers/buttons and the fact that standard definition channels are not very popular anymore when an HD version is available.
I'm not sure which cable box you currently have, but it sounds like you may have an older one that does not have a very big hard drive if you are concerned about space. Our latest contour receiver has 2 terabytes of storage which should last a very long time before needing to delete recordings.
Brian
- gymanime6 years agoNew Contributor III
I have 3 9865 dvrs. Not enough storage without extra external HDDs. Open the eSata.
- 3 years agoFlighthawk
- 2 years agoCUTiger78
- 4 years agoJC
- 6 years agoBen12
