JonathanJ
4 years agoFormer Moderator
The light is blinking because it is still in the activation process. Please follow the steps below.
1. Disconnect the USB cable from the Tuning Adapter.
2. Unplug the power cord from the wall, wait 30 seconds and plug it back in.
3. Wait up to 30 minutes for lights to stop blinking.
4. Once the light is steady for one minute or goes out, reconnect the USB cable.
5. Wait at least 10 more minutes and check to see if channels are now viewable.
If you continue to have issues with activating the tuning adapter, contact our activation team at 1-800-699-8151.
Cox Moderator
Cox Moderator
- Forum_User4 years agoNew Contributor II
Hi Jonathan,
I've seen that procedure before, and have tried it many times over the past few weeks. The LED never turns steady. And I've called Cox tech support several times and they attempted to "activate" each of the adapters I have tried.
- LisaH4 years agoModeratorPlease try to see if it works now. - Lisa, Cox Support Forums Moderator.
I tried it again, same result. The power cycle procedure that is
- 12 months agoToml66
- 2 years agoDesert_Rat
- 9 years agodekarske
- 11 years agoPKuz
- 11 years agolouistong
