gina6371's avatar
gina6371
DVR problems
When playing my recordings back (on both of my DVRs) they video will freeze with audio still going as well as the audio cutting out completely. Booth DVR are only at 7% full, module number AX061AEI. This does not happen with live tv.
  • gina6371's avatar
    gina6371
    Also kicks me out of recordings with the error code XRE-06014
    • krach's avatar
      krach
      I had two series scheduled to record tonight I went to watch them it said a long paragraph of network error so I restarted it and the recordings disappeared. This has been going on for 4 days now. I am so over cox. I pay way too much money to have issues. I git this new dvr less then 3 months ago. 😡😡
      • Allan's avatar
        Allan
        @Krach. Are you able to setup a manual recording and see if it records? If not, are you getting the same error message? -Allan, Cox Support Forums Moderator
    • Allan's avatar
      Allan
      @Gina6371 Are you having this issue using the dvr box or are you trying to watch the recording on a client box? -Allan, Cox Support Forums Moderator.
      • gina6371's avatar
        gina6371
        It is the box that I gave the model number for in my original post.
