At the screen bottom right there is a Language Setting icon that has 3 buttons that can be slid on/off. the 2nd is Secondary Audio (SAP).
You can also toggle SAP by pressing "S" on the keyboard.
? - Display keyboard controls
C - Toggle closed captions
M - Mute audio
S - Toggle SAP
V - Toggle video description
CurtB...Wow, look at this info, Awesome with all your great thoughts and insight. You sure are into many of these hidden gems along with your technical contribution. The ?, which opens the Keyboard Shortcuts could be invaluable to the Cell Apps guys....eliminates picking something on the screen.
Still no resolution to the Sound issue for watchtv or Apps from Cox. Hope users with issues can find some hope to this dilemma.
- CurtB5 years agoValued Contributor III
Click "Player Settings" (wheel in lower right of screen). Then click "Player Shortcuts" (box in upper right of the just opened pop up). I tend to explore stuff to see what's available.
I would try toggling Mute (M) On and Off for those channels with no sound. It probably won't help, but you never know.
- 5 years agokristiemom26
- 7 months agojillrenee1973
- 10 years agoglo
- 2 years agoWiderMouthOpen
