Sunnyday
7 years agoNew Contributor
Yes, I have the exact same problem. I just had a Contour 2 Box installed on 1/1/18 and it is hooked up to my Onkyo 4K Receiver which feeds a 4K Sony TV. Every morning it reverts back to STEREO for Sound and 720P on Resolution. I called Cox and told them about this forum and to check for firmware updates. They said all looks fine. I have Cox coming out in the morning to replace the box. I will let you know if this helps like it seems to with others. I did check the TV for Bravia Sync and it is off
