Bjensen
7 years agoNew Contributor
Erica,
The settings are certainly reverting to some default state and do not keep the higher resolution/audio selection I choose. There is a noticeable difference in both video and audio quality. I can also see that my audio receiver is not decoding the Dolby signal once it reverts back. I'm familiar with my TV and sound system capabilities but new to the Contour 2 box.
This only happens after the cable box sits overnight (maybe goes though an update cycle?). I have tried turning off the sleep functions to no avail. It will keep the settings I select in the morning through the evening. After doing a little searching, I've noticed other customers having a similar issue.
