JonathanJ
@Mare70
If you're still having an issue please try rebooting the cable box and see if that helps. If still having an issue after please email your full-service address and name to cox.help@cox.com.
Cox Moderator
Cox Moderator
HDTV_Guy
5 years agoContributor
I dont use a cable box...cablecard only. For some reason with no action by me, its been clear for the past few days. Can a root cause be determined and communicated to the community? This may help future issues.
- Allan5 years agoModeratorHello HDTV_Guy. Since you are using a cable card, I recommend rebooting the tuning adapter. Please let us know if there is any change. Thanks. -Allan Cox Support Forums Moderator.
- 4 months agoAudi74
- 26 days agokcostel8621
- 9 years agosocal_transplan
- 10 years ago0uid
- 2 months agoFAurelio
