Attmay's avatar
Attmay
4 years ago
Upload speed much slower than advertised
My plan has 1MBPS upload, but I only get 10~15% of that. I'm looking at activity monitor right now (As I'm uploading a file), and I see 0.127 MBPS.
Funny thing is that when I try the Cox speed test, suddenly my upload rate jumps up to the advertised amount. So I'm sure the issue is not on my hardware.
Is there anything I can do to fix this?
  • BenS1's avatar
    BenS1
    Hi @Attmay ,
    If you are doing a speed test and you get the right speeds then you may want to look at what is going on with your device you are uploading. Are you connected to a VPN when you are uploading? Are you doing any gaming or streaming?
    Ben S.
