TR95's avatar
TR95
6 months ago
speed locked at 30mbps
To start i thought i had a issue with an older router replaced it , did not fix to speed issues.
I have talked with netgear support for my modem cm700 and they say that my isp needs to push a firmware update and that the modem is "locked in a default state at 30mbps.." please advise/ help with this situation.
refrence points
modem netgear cm700 net gears supposed firmwarev1.02.04
router brand new erro 6 pro
  • SOLVED  hope this helps someone, after multiple factory resets to modem i have full speed and currect firmware on my side. so  i guess just factory reset till it works! shame netgear couldnt have mentioned that lol.
  • TR95's avatar
    TR95
    • CurtB's avatar
      CurtB
      Valued Contributor III
      TR95 wrote:
      SLOVED
      OP "SLOVED" his own post.  πŸ˜„  (Hint: you can click the three horizontal dots to edit your post).
