ChipG's avatar
ChipG
7 years ago
Speed issue, I have ultimate speed service and I 'am lucky to 100mps tech has been here.
Sun Dec 31 07:02 AM Yes 95 Mbps 32 Mbps 12 millisec 68.228.214.9 Phoenix Sat Dec 30 06:28 PM Yes 95 Mbps 32 Mbps 12 millisec 68.228.214.9 Phoenix Sat Dec 30 12:45 PM Yes 95 Mbps 32 Mbps 12 millisec 68.228.214.9 Phoenix Thu Dec 28 05:34 PM Yes 95 Mbps 32 Mbps 11 millisec 68.228.214.9 Phoenix Thu Dec 28 12:02 PM Yes 95 Mbps 32 Mbps 12 millisec 68.228.214.9 Phoenix Thu Dec 28 11:37 AM Yes 95 Mbps 32 Mbps 11 millisec 68.228.214.9 Phoenix Thu Dec 28 11:14 AM Yes 95 Mbps 32 Mbps 12 millisec 68.228.214.9 Phoenix Thu Dec 28 12:44 AM Yes 385 Mbps 32 Mbps 11 millisec 68.228.214.9 Phoenix Sat Dec 27 04:23 PM yes 79 Mbps 12 Mbps 12 millisec 70.176.242.78 Phoenix Tue Dec 13 05:53 PM yes 186 Mbps 11 Mbps 11 millisec 70.190.214.236 Phoenix Thu Nov 27 11:50 AM yes 79 Mbps 12 Mbps 12 millisec 70.176.242.78 Phoenix Wed Nov 18 07:00 PM yes 65 Mbps 12 Mbps 13 millisec 70.176.242.43 Phoenix Mon Nov 17 01:30 PM yes 78 Mbps 12 Mbps 12 millisec 70.176.242.78 Phoenix Tue Nov 08 06:04 PM yes 170 Mbps 12 Mbps 12 millisec 70.190.214.236 Phoenix Sun Nov 06 09:17 PM yes 169 Mbps 12 Mbps 11 millisec 70.190.214.236 Phoenix Wed Nov 05 02:34 PM yes 81 Mbps 12 Mbps 12 millisec 70.176.242.78 Phoenix Fri Nov 04 06:17 PM yes 169 Mbps
  • DJGem's avatar
    DJGem
    Here's a quick way to find out where the problem (or should I say BLAME) may lie....
    On a Windows computer:
    Click on the "start" icon (bottom left corner) --> go to the search box (the ONLY open empty box you can type in) and type in cmd then press enter
    A black box will pop up --> type in ping -t cox.com then press enter....
    You should see something like this:
    C:\Users\Mimi>ping -t cox.com
    Pinging cox.com [45.60.49.167] with 32 bytes of data:
    Reply from 45.60.49.167: bytes=32 time=121ms TTL=253
    Reply from 45.60.49.167: bytes=32 time=122ms TTL=253
    Reply from 45.60.49.167: bytes=32 time=123ms TTL=253
    Reply from 45.60.49.167: bytes=32 time=120ms TTL=253
    Let that run for about 10 minutes or so then press the Ctrl button and, at the same time, press the "C" key on your keyboard --> the following will pop up next....
    Ping statistics for 45.60.49.167:
        Packets: Sent = 8, Received = 8, Lost = 0 (0% loss),
    Approximate round trip times in milli-seconds:
        Minimum = 120ms, Maximum = 123ms, Average = 121ms
    You want to be looking at that MAXIMUM..... If that's high then there are definitely issues.... If there are issues then run the next test.....
    In the same black box type in tracert cox.com and press enter. You should see something similar to the following:
    C:\Users\Mimi>tracert cox.com
    Tracing route to cox.com [45.60.45.167]
    over a maximum of 30 hops:
      1    11 ms    17 ms    13 ms  10.5********** (blanked out for my protection)
      2    15 ms    13 ms    14 ms  100.127.74.24
      3    22 ms    19 ms    17 ms  100.120.100.12
      4   372 ms    29 ms    15 ms  lag-194.bear1.Phoenix1.Level3.net [4.31.188.61]
      5     *        *        *     Request timed out. <----BAD!!!!!
      6   177 ms    31 ms    32 ms  4.7.26.34
      7    31 ms   179 ms    36 ms  45.60.45.167
    Trace complete.
    See that section marked BAD??? Yeah, that means something's BROKEN..... If you see high connection time (the section that's in "ms" = milliseconds) or if you see what's in mine (timeout) then you have something to work with. Let's say I'm having slow speeds, I'll run another test to a site that's NOT owned by Cocks......
    C:\Users\Mimi>tracert yahoo.com
    Tracing route to yahoo.com [206.190.39.42]
      1     9 ms    15 ms    22 ms  10.5********** (blanked out for my protection)
      2    16 ms    25 ms    15 ms  100.127.74.26
      3    22 ms    16 ms    19 ms  100.120.100.16
      4    28 ms    28 ms    27 ms  68.1.4.252 <---- LAST COX CONNETION
      5    33 ms    28 ms    29 ms  UNKNOWN-216-115-101-X.yahoo.com [216.115.101.244
      6    29 ms    36 ms    27 ms  UNKNOWN-216-115-102-X.yahoo.com [216.115.102.186
      7    48 ms    41 ms    43 ms  UNKNOWN-216-115-104-X.yahoo.com [216.115.104.79]
      8    90 ms    59 ms    61 ms  ae-6.pat2.swp.yahoo.com [216.115.100.91]
      9    94 ms    64 ms    62 ms  ae-7.pat1.gqb.yahoo.com [216.115.96.45]
     10   121 ms    62 ms    64 ms  et-1-0-0.msr1.gq1.yahoo.com [66.196.67.101]
     11    63 ms    63 ms    63 ms  et-0-0-0.clr2-a-gdc.gq1.yahoo.com [67.195.37.73]
     12    63 ms    71 ms    63 ms  et-17-25.fab4-1-gdc.gq1.yahoo.com [67.195.1.87]
     13   240 ms    63 ms    64 ms  po-12.bas2-7-prd.gq1.yahoo.com [206.190.32.35]
     14    60 ms    57 ms    55 ms  media-router-fp1.prod.media.vip.gq1.yahoo.com [2
    06.190.39.42]
    Trace complete.
    That section that I marked is the last place that Cox physically has any control over your connection to the outside world basically. If you're seeing high connection times or timeout's before that last Cox connection then the issue is COCKS!!!
    Don't let their so called tech support beat you up; use tools available to you to challenge them and PROVE they are the one's with issues.....
  • Hello ChipG,
    Is the speed loss intermittent, and was the issue happening during the appointment when the technician used his tools to check the speeds?
