ckenobi's avatar
ckenobi
Red Dead Redemption 2 Online connectivity issues. Open port help?
I called Red Dead Redemption 2's tech support after I stopped being able to connect to the PS4 online game. R2 support said I should call Cox and have them open the below ports to help. If I call Cox, will they actually open these ports for me? I have my firewall set to Low so that no services are restricted.  In Advanced options, I have PPTP and UPnP enabled. Is there a way for me to open the ports myself?
https://support.rockstargames.com/articles/360012932454/Red-Dead-Online-Connection-Troubleshooting-for-PlayStation-4
Check your Open Network Ports
PlayStation Network uses the following ports for communication with game servers:
  • Port 465 (TCP)
  • Port 983 (TCP)
  • Port 1935 (TCP)
  • 3478 (TCP)
  • 3479 (TCP)
  • 3480 (TCP)
  • Port 3478 (UDP)
  • Port 3479 (UDP)
  • 10070 - 10080 (TCP)
We Recommend the following additional ports to be opened for Red Dead Online:
  • Port 6672 (UDP)
  • Port 61455 (UDP)
  • Port 61456 (UDP)
  • Port 61457 (UDP)
  • Port 61458 (UDP)
  • Ports 30211-30217 (TCP)
