Just to clarify, this problem has happened every day since 3/20/2019. It happens every hour, regardless of time of day. It happens for 5-10 minutes at a time. During that time, speed test upload speed drops to 0. Download speed is less noticeable and only drops to 20-60 mbps. This isn't a problem that most internet users would even notice so nobody is likely to report it and it could be affecting a lot of users and not just me. My roommate streams for a living so this is career breaking. For 10 minutes every hour, his stream basically cuts out for 10 minutes. The connection is so bad that OBS drops the connection sometimes and he has to reconnect. Other times it's just like 1 FPS. It's unwatchable. The upload bandwidth is basically 0 for 10 minutes out of every hour.
- mike_thorne6 years agoNew Contributor
load ccleaner, then go to options and stop all the stuff thats slowing you down, i have the pro edition myself it works great on free also
if your using firefox then you have a shitload of stuff slowing you down bro load ccleaner i'm not affiliated with them at all just a regular guy then go to plug ins then options and stop all that *** you dont want disable it
- Michael-MS6 years agoNew Contributor III
I'm not even using a browser when this happens. I am losing connection on Streamlabs OBS, Discord, and whatever game I'm playing. This happens on two separate computers. The loss of internet is also visible on any device speed test during the outage time period. It's a problem at the node. I have been doing tech support for a living for 15 years so I'm familiar with all that can go wrong on a PC. Thank you for the advice though.
- 9 years agoFujiwaraTakumi
- 8 months agoWiderMouthOpen
- 11 years agokane
