- bigbopper5 years agoNew Contributor
Thanks Allan. Here's an subset showing the numbers after about 24 hours. Note the channels above and below the 902-928 range. There are no amps anywhere. The cable drop goes from the outside up to the attic where there is a splitter that has at least 3 outputs going to each of three locations in the house. I have not gone up in the attic to look. I believe RF interference is more likely right where the smart power meter and the outside cable drop are co-located. I know the downstream power levels are low, but that is not a problem. Many of the other 32 downstream channels have much better signals. To the right of the SNR numbers are correctables and uncorrectables in that order.
18 Locked QAM256 885000000 Hz -9.3 dBmV 36.4 dB 1 0 19 Locked QAM256 891000000 Hz -9.5 dBmV 36.2 dB 2 0 20 Locked QAM256 897000000 Hz -9.7 dBmV 35.7 dB 7 0 21 Locked QAM256 903000000 Hz -9.8 dBmV 35.8 dB 980417 3989287 22 Locked QAM256 909000000 Hz -10.0 dBmV 35.6 dB 754675 3717438 25 Locked QAM256 927000000 Hz -11.0 dBmV 35.3 dB 346930 1801558 26 Locked QAM256 933000000 Hz -11.7 dBmV 34.9 dB 10 0 27 Locked QAM256 939000000 Hz -12.6 dBmV 34.2 dB 11 0 - KevinM25 years agoFormer ModeratorHi Bigbopper, can you please include a link to this forum thread and send us an email at cox.help@cox.com, for further troubleshooting? I would also recommend performing a hard-wired speed test using the Cox website, http://bit.ly/2VsdGbX. Additionally, here's an article which discusses ways to improve your internet experience, http://bit.ly/2Kq4uR5. -Kevin M. Cox Support Forum Moderator
Thanks. I'm not having any speed problems. My service is 100 down and I'm getting 80+ wireless and closer to 100 hard wired. Only question is correctibles/uncorrectibles on the channels that overlap the 902-928 MHZ ISM band. My internet experience is fine.
- 8 years agoJaester
- 11 years agostinkfoot63
- 8 years agoDivermike
